Use this task to disable a user account using EDM.
You cannot disable users with rwa access rights. Only users with ro and rw access
rights can be disabled.
In the navigation pane, expand
Select General.
Select the Multiple Users
tab.
In the
Enable column, double-click the cell, and then select
false.
Select Apply.
